Help choosing stainless brake line kit
4WDTRK
sleeps in garage
Socal dreaming of Norcal
I want to upgrade to stainless braided lines when I do a brake job soon. Which is the best kit for a 2006 LS with stabilitrak (Russell, Stoptech, Centric, Goodridge, etc.)? I've read some kits don't include all the hoses for the rear (5 instead of 6) and others report them not fitting correctly.
4WDTRK
4WDTRK
sleeps in garage
After doing a lot of digging it looks like the Goodridge kit has been retrofitted to correct the previous issue with the 6 line kits for trucks with stabilitrak. Guess I'll give them a try.
Goodridge part# 14196 if anyone needs it.
4WDTRK
4WDTRK
sleeps in garage
What calibers are you going to run up front? Lots of info on upgrading to a 2 or 4 piston caliber on here.
I was back and forth on going the NNBS upgrade route, but didn't want to shell out the $$$ on calipers. Was just going to stay stock and go with Z36 Powerstop rotors and pads.
blueinkd
So what's the concensus on this?? I'm fairly close to pulling trigger on my 4 piston swap and want to replace the front lines. I may just get new ac Delco for the rear ones. 2005 LT Tahoe 2wd here
carloogbuyNuh
