You need to be a HELLUVA lot more descriptive with anything.
Do you hear the noise in the cabin? If so, does it get more noticable when you are at a stop with the engine running, and the blower motor off?
Is it more noticable outside the cabin? It it more noticable under the hood? Are there any changes when the A/C clutch kicks in and out? Is there any change, if applicable, when the mechanical fan clutch engages and disengages?
-Does the noise start when the engine is running? Is it noticable as yu are driving, or only at stops? Does it change with drive speed, or transmission gear?
You see where I'm going? There's a $hit ton of things it could be, but we haven't got a clue as to where to start since you didn't provide any useful data to start.
-Junior
