TURNz
- Joined
- Jan 30, 2012
- Posts
- 168
- Reaction score
- 27
2004 Suburban Z71:
When making a slow left hand U-turn, *click click click* from under the truck. No sound when making the same turn to the right. No sounds when going straight. Though my wife has heard a single POP while going straight on two different occasions recently. But not multiples. So I'm not sure if that would be related.
I assumed CV Axle. I got underneath and the boots are in perfect condition. No tears, no grease leaking out. That was as far as I was able to go with troubleshooting last night. I'm hoping to jack each side up tonight and give them a spin. Though I don't know if it'll make any noise without the vehicle weight on it.
The axle boots look fairly new on both sides. I'm wondering if they were replaced by the previous owner.
How can I make sure that the CV Axle truely is the issue before I spend the money to change it? Also, if it is the Axle, would it be the right or left causing the problem, considering the LEFT u-turn is when the noise occurs.
