Help me find this oil leak please!
SnowDrifter
Washington. The starbucks side not the desert side
1. Whoever did the work is a ******* idiot and they're trying to pawn off bad work. I'd look into getting your money back. Replacing an oil pan gasket doesn't cause more 'pressure' anywhere else. They're bullshitting you hoping you go away
2. Clogged cats won't cause an oil leak. It'll do a whole lot of things, but an oil leak isn't one of them.
3. Look into a UV dye kit if you're having trouble locating it. That much oil coming out of the motor, I can't see this being all that elusive to find
4. How's you PCV valve? If that's plugged you can run into some leak issues
John03Z71
John03Z71
Reviving this thread from almost exactly a year ago, as my leaks never completely went away and now it's quite bad again. I'm losing about a quart of oil per week now (about 250 miles +/-). Seems to be more in the front of the engine this time as everything up front is soaked in oil, and I think the light amounts on the rear are just from blowback on the highway.
Here's what I have replaced:
Rear main seal, oil pan gasket, oil cooler block off plate seal (last year)
Oil pressure sensor (several years ago)
When the shop that did my oil pan gasket had it in there last year they told me my timing cover gasket was starting to leak a little, so I'm thinking that may be the culprit. Is this the same thing one might refer to as the "front main seal"? The shade tree mechanic that helped me with my rear main job last year told me the front main was starting to leak a bit.
Valve cover gasket on passenger side shows a little bit of dampness beneath it but definitely not shiny wet with oil or anything.
So I guess my question is, besides what I've already done (and valve cover gaskets) what else is left that could be the culprit? Everything is covered in so much oil it's very hard to visibly tell, I might have to get a UV dye kit. Also if the timing cover is the culprit, how hard is the job for a fairly competent DIY'er with basic tools? And how many hours labor would a shop likely charge?
Thanks in advance!
SnowDrifter
Clean it up and look around. Not trying to be a smartass but we don't have a crystal ball that'll tell us which gasket has failed based on the description of a dirty engine. If you're unwilling or unable to look around, then the forums really aren't your best bet for this and you'd be best off taking it to a trusted mechanic. All we could do is speculate. Someone, somewhere, needs to get hands on with your rig.
Timing cover needs to come off to do said gasket. Front crank seal is pressed into the timing cover. It would be prudent to do both at the same time if you find that's the issue.
Run down of the gaskets and other oil contacted components that are in your engine, more or less in order from top to bottom:
- Valve cover gaskets, including grommets and PCV system
- Oil pressure sending unit, camshaft position sensor
- Valley pan gasket, including grommets for knock sensors. Located under the intake manifold
- Front and rear covers, including front/rear main seals which are pressed in
- Oil galley plug on the front left side of the engine roughly at the same elevation as the crank, crankshaft position sensor located by the started
- Oil cooler lines or block off plate, depending on your rig. Located just above oil filter
- Oil pan gasket - interfaces with front/rear cover gaskets
- Oil level sensor on the driver's side of the oil pan
- Oil drain plug
John03Z71
John03Z71
Last night after swapping out my O2 sensor I spent a little time trying to figure out where the oil leak(s) is coming from. I started the engine and crawled underneath for several minutes watching for drips. I found that there is an area above that O2 sensor (bank 1, sensor 1 - driver's side before cat) that is dripping down onto the exhaust, which is then causing a bit of smoke with each drop. (This would also explain why I smell burning oil coming from the air vents).
These aren't the best pics but do they, along with the description above, help anyone narrow down a potential source of the leak? Also I believe I have multiple leaks as when I park there are spots under the front and back of the engine... the spot under the back side is usually between the size of a softball and frisbee..
I'll try to get some more and better pics this weekend.
Thanks in advance for any help.
JetBlackNali
Vancouver Canada
Oil cooler line? Metal to rubber fitting near front of block. On mine it was this fitting. At idle small drip but once the rpm increased a spray to the power steering pump area at front of block. Then blow back on highway and it took me a good week to find. Was covered all the way back to trans. Actually degreased and pressure washed the underside of engine. Dried and fired it up. Layed under there for 20 minutes and got a single drip. ????. Got the wife to rev it up and holy sh*t. There it was, a pinhole and a concentrated spray. These are known leakers. Metal expansion in the aluminum crimps. Another not so great design. (But it does make it easier to route when you have to change them). No brainer for me, aftermarket oil cooler and lines for me. 4 years and not a drop.
retiredsparky
Maybe you didn't see the posting about a clogged pcv valve. You can replace every oil related gasket on the engine, but if the pcv valve is clogged, pressure will build inside the crankcase and push oil past most of the seals on the engine.
The reason this happens is that as the engine ignites the gas/air mixture, some of the resulting high pressure gases are pushed past the piston rings into the crankcase. The pcv valve vents these gases into the intake of the engine and relieves that crankcase pressure if it is working properly.
John03Z71
John03Z71
Thanks for this suggestion (and the previous). I checked the PCV valve today and the bottom side of the fat end (facing down into valve cover) had a very thick layer of hard residue buildup that was definitely blocking the hole, it was caked on so thick that when I sat it down on the ground it tipped over because the bottom surface was rounded due to the buildup and no longer flat.
Haven’t had any idle or misfiring issues though. Popped the new one in and am keeping my fingers crossed. I don’t expect it will magically stop all my oil leaks, but even if it slows down a bit I would be happy... we’ll see. Thanks again for the input.
mattt
Did yours have a removable PCV valve? Most in this generation just have a fixed orifice in the valve cover that acts like a PCV valve. Did you remove the valve cover to check it?
John03Z71
John03Z71
Yes I just pulled the vacuum hose off the valve cover (drivers side rear of engine). The PCV valve is in the end of that hose. I was able to pull the old one off with just my hands and a little elbow grease... put the new one in, then popped the hose w/ new PCV valve back in the top of the valve cover.
yukonxlv
Michigan
Found plugged PCV system on high mileage 02 Yukon while chasing after similar leaks. A plugged crankcase venting system will start leaking oil even in places that not typically under pressure. The 02 original driver side valve cover was caked with carbon in the vented area inside the valve cover. At that time GM had a 3rd design valve cover available with much improved venting and built in PCV valve. Also needed a longer hose. How does the inside of your vent system for the valve cover look?
Mujahed
