Help me put together a write-up for an in car PC w/ OBD2
gulleyman
gulleyman
TX.
Darn, thought that might mean it could read all the other codes too :(
The OBDLink offers a "GM Enhancement" for another $79.
There's also mention of another freebie called "GM Mode 22 Scan Tool by Terry" but I can't seem to find a description of it anywhere, just a bunch of places to download it...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
1. It does but mode 6 capability is ussually not included in most software becuase a one fits all does not really carry generic mode 6 info. The variables changes from maker to maker. It may support it but there was no list of whats covered for GM or is it another module to buy?
2. That gm enchancement was the one I recomended with the ScanXL Pro.
3. It is a really basic data displayer and dtc reader took 2 minuts to download and install.
gulleyman
gulleyman
TX.
Hey, so you have already played around with the "GM Mode 22 Scan Tool", guess it didn't get ALL the info huh?
I'm starting to lean towards the ScanXL to start and just order the "GM Enhancement" later if we don't get all the info we're looking for.
Check this out, I got a response back from someone at ScanTool:
"The transmission usually sits on the same OBD bus as the ECM. However, you are probably not going to have access to ABS, as that module usually sits on a non-OBDII bus.
OBDLink does support some additional commands that let it access enhanced ABS and transmission trouble codes, but these commands are only useful on newer GM CAN vehicles.
I would shoot an email to PPE with your vehicle information, and see what they say."
I don't know who PPE is yet (perhaps Palmer Performance?) but hopefully they too can help figure out just how much information can possibly be pulled out of this '97 Yukon :D
SunlitComet
OBS Jedi-Do Good
Demoed both mode 22 was very basic info plus o2 sensor voltages. Still going for ScanXlPro and the gm add-on myself when I have the money.Just ask PPE for details They are palmer performance engineering. Just6 remember I believe the gm add-on was required to look at the cam offset issue that came up so IMO it would be needed any time the distributor is moved.
gulleyman
gulleyman
TX.
Demoed both mode 22 was very basic info plus o2 sensor voltages...Just ask PPE for details...Just remember I believe the gm add-on was required to look at the cam offset issue that came up so IMO it would be needed any time the distributor is moved.
Sent them an email earlier this morning, hopefully we'll find out pretty soon. Should also a good indicator of what the support will be like...ain't it? :anitoof:
---------- Post added at 02:31 PM ---------- Previous post was at 12:39 PM ----------
Just some additional info on my setup and some that I've seen to give you guys something to look at while we're sorting this all out :laughing1:
I'm running a Xenarc 700IDT In Dash 7 inch VGA Touch Screen display that I used on a previous install, had it installed in the CD pocket of a NBS Chevy Z71, totally stealth install, looks like this:
There will be a slot load DVD drive like this one installed in an undetermined location
7857_Sony_SN-T083C_8X_SATA_Notebook_Slimline_Slot_Loading_DVD_Writer_DVD%C2%B1RW_Writer_Black_-_OEM_l.jpg
Using the Scorpius P20 2.4 Ghz Wireless Keyboard With Joystick Mouse:
Still gotta dig the info on that MCS case for you guys. It's a pretty slick setup specifically designed for 12v automotive applications. Gonna drop a couple gigs of ram and a 100gb hard drive loaded with music, music videos and movies :word:
Carputers or carPC's have to have a "front-end" software to make them car friendly for the little screens and touchscreen applications. I'm probably gonna go with Streetdeck, Centrafuse or Riderunner
I'll also have the GPS and Rear Back-up camera in place and maybe a webcam...maybe
Here's some pics of installs I've seen:
I'll have to dig up some pics of my last couple of carPC's for you guys. Pretty sick stuff, kinda getting excited just talking about it again :rockit:
Nikolai553
Hutchinson, KS
How much does that little handy screen cost?
( i would probably find a omni antenna to hide some where to pick up wifi on the go ;D )
gulleyman
gulleyman
TX.
I think I paid about $400 for mine new, that was the most expensive part by far. You could probably pick up a used one for about half that though, maybe even less. The wifi is already built into the PC Case too lol. The last one I had actually would do traffic cams in real time through the GPS program :gr_grin:
It was a pretty slick set-up, came ready to go right out of the box, just plug in and play and it was only about $650
Nikolai553
Hutchinson, KS
me wants! :****:
gulleyman
gulleyman
TX.
OK, so I got a response from Weston of ScanXL and here's the PIDs in their database for the 5.7L L31:
TP Sensor
TP Angle
MAP Sensor
MAP
Intake Air Temperature Sensor
Engine Coolant Temperature Sensor
Barometer
HO2 Sensor Bank 1 Sensor 1
HO2 Sensor Bank 1 Sensor 3
Long Term Fuel Trim Bank 1
Fuel Trim Cell Bank 1
Short Term Fuel Trim Bank 1
HO2 Sensor XCounts Bank 1
Engine Speed
Desired Idle Speed
IAC Position
Desired IAC
HO2 Sensor Bank 2 Sensor 1
Long Term Fuel Trim Bank 2
Fuel Trim Cell Bank 2
Short Term Fuel Trim Bank 2
HO2 Sensor XCounts Bank 2
KS Activity
Knock Sensor
Spark Advance
Knock Retard
EVAP Duty Cycle
EGR Duty Cycle
Actual EGR Position
Desired EGR Position
EGR Sensor
Injector Average Bank 1
Injector Average Bank 2
Ignition 1
Air Fuel Ratio
Engine Run Time
Cam Retard
Cylinder Mode Index
Revolution Mode Misfire Index
Cycles of Misfire Data
Misfires per Cycle Status
Misfire Current Cylinder 1
Misfire Current Cylinder 2
Misfire Current Cylinder 3
Misfire Current Cylinder 4
Misfire Current Cylinder 5
Misfire Current Cylinder 6
Misfire Current Cylinder 7
Misfire Current Cylinder 8
Misfire Failures
Total Misfire Pass
Misfire History Cylinder 1
Misfire History Cylinder 2
Misfire History Cylinder 3
Misfire History Cylinder 4
Misfire History Cylinder 5
Misfire History Cylinder 6
Misfire History Cylinder 7
Misfire History Cylinder 8
Number of Misfires
Number of Normals
Engine Load
Mass Air Flow
Loop Status
KS Adjust Factor
Current Gear
Shift Delay
Shift Pattern
Shift Time 1-2
Shift Error 1-2
Shift Time 2-3
Shift Error 2-3
Shift Time 3-4
Shift Error 3-4
Output Shaft Speed
Vehicle Speed
PCS Desired Current
PCS Actual Current
PCS Duty Cycle
TCC Duty Cycle
TCC Slip Speed
TCC Ramp
TCC Apply
TFT Sensor
TFT
Turbine Speed
TAP 25% TP
TAP 31% TP
TAP 38% TP
TAP 44% TP
TAP 50% TP
TAP 56% TP
TAP 63% TP
TAP 69% TP
TAP 75% TP
TAP 81% TP
TAP 88% TP
TAP 94% TP
TAP 100% TP
Last Adapt Pressure
Long Term Fuel Trim Enable
Rich / Lean Bank 2
Rich / Lean Bank 1
Rear HO2 Sensor
Front HO2 Sensor
Spark Control
EVAP Canister
EVAP Vacuum Switch
DTC This Ignition
Ignition 1 On
Ignition 1 Low
Ignition 1 High
Brake Switch
Hot Mode
4WD
4WD Low
Start of Shift
End of Shift
Upshift in Progress
Shift is Complete
Throttle Out of Range
Large Thorttle Delta
Large Speed Delta
Transmission Range Switch
Last Shift Adapt
Power Enrichment
Throttle Kickdown
Cruise Mode
3-2 Downshift Solenoid
Transmission Range Switch A
Transmission Range Switch B
Transmission Range Switch C
1-2 Solenoid
2-3 Solenoid
Maximum Adapt
Long Shift Delay
Long Shift Time
A/C Request On
A/C Enable Relay
A/C Request
A/C Compressor
Solenoid A (1-2) Open Ckt
Solenoid A (2-3) Open Ckt
TCC Enable Open
TCC Open Ckt
PCS Off Low Volt
Part Number
Software Level First Digit
Software Level Second Digit
Part Number
Part Number
Engine Torque
Mass Air Flow Sensor Frequency
Start Up Intake Air Temperature
Current Gear
Shift Time 1-2
Shift Error 1-2
Shift Time 2-3
Shift Error 2-3
Shift Time 3-4
Shift Error 3-4
Output Speed
Vehicle Speed
PCS Desired Current
PCS Actual Current
PCS Duty Cycle
TCC Duty Cycle
TCC Slip
Transmission Fluid Temperature Voltage
Speed Ratio
1-2 TAP 25% of TP
1-2 TAP 31% of TP
1-2 TAP 37% of TP
1-2 TAP 44% of TP
1-2 TAP 50% of TP
1-2 TAP 56% of TP
1-2 TAP 75% of TP
1-2 TAP 81% of TP
1-2 TAP 88% of TP
1-2 TAP 94% of TP
1-2 TAP 100% of TP
2-3 TAP 25% of TP
2-3 TAP 31% of TP
2-3 TAP 37% of TP
2-3 TAP 44% of TP
2-3 TAP 50% of TP
Last TAP
Clutch Switch
Closed Loop Since Restart
Rich/Lean Bank 2
Rich/Lean Bank 1
Post HO2S
Pre HO2S
Spark Control
EVAP Canister
Ignition 1 On
Ignition 1 Low
Ignition 1 High
Brake Switch
Hot Mode
4WD
4WD Low
TCC Forced Off
TCC Enabled
Decel Fuel Mode
Transmission Range
Last Shift Adapt
Power Enrichment
Cruise Mode
1/2 Solenoid
2/3 Soleniod
Maximum Adapt
1-2 Solenoid Open/Short to Ground
2-3 Solenoid Open/Short to Ground
3-2 Downshift Solenoid Open
Power Take Off
1-2 Solenoid Short to Volts
2-3 Solenoid Short to Volts
A/C Request
A/C Clutch
Start Up Engine Coolant Temperature
What'chya think sunlitcomet, will this be enough to diagnose that random misfire?
Roblusk
