Help! Need new sway bar and axle on lifted truck.
Trey Hardy
Eastern North Carolina
I have a 2012 Hoe with a 3.5" RC lift. The truck is 4WD without air suspension. The sway bar bracket rusted off the frame (the frame looks good underneath bracket). I am going to get a new bracket welded (unless you know of other options) and replace the sway bar links. One of my axles is also spewing grease and needs to be replaced. Can I go with OEM options or should I do extended links and/or axles? Also, should I replace the sway bar? I cannot get a look at it because the truck is undercoated.
Stock links should be fine just weld a new mount onto the frame and same with the axles as long as you have a differential drop already if you don’t then get one
bobbywdatool
