HELP! NO INJECTOR PULSE,...non running 96 suburban tried everything
C
corbin dallas
OK UPDATE! its running!!!! not 100% sure but after trying new computer, ICM, even steering column wiring harness nothing at all. I even lost the spark as well as injector pulse. so I cleaned and remounted the two wires on the thermostat gooseneck,..then found the fuseable link at the back of passenger side engine block broken off and the other wire wasnt very tight. fixed both connections. then put another(no 3) crank sensors in it and then noticed the wires to the plug all bare and pulled out somewhat. i just made sure they were not touching,..afeter all of that i tried starting,..it did!!!!. so now just going to get a new plug at the junkyard and solder it in. not sure what did it,..but those were 3 obvious problems i solved and that combo fixed it. thanks for everyones help!!!
Ta6112
