Hi there
I have a 2007 Tahoe LTZ 5.3 flex fuel, It has 157k miles and I just bought it from a dealership as is. It looks like some oil changes were not done in appropriate timing as the oil was a bit caked on so I did some extensive repairs. I had a lot of problems with oil pressure so I replaced the oil pump and solved the problem. (Just in case anyone asks I out sealant on the mating channels of the other gaskets). Now I’m having a tapping sound which I believed to be a lifter jumping and not making me feel good about this. When I did pull the engine oil pan I found small amounts of shaved material and little bit particles of metal. I am to believe from this that my lifter somewhere on cylinder 4 or 6 is bad, might be so bad it chewed the cam lobe. I have the money to pay a shop to do it but I have a little bit of Intermediate mechanic skill. However I’ve never done a camshaft replacement, especially not on a v8. My few questions are should I upgrade anything while I have the heads off? How can I prevent future problems? Good examples to look out for damaged engine parts? Or soon to be problems?
note: I am going with a AFM DOD Delete kit that comes with a camshaft and a tuning module.
TLDR: Bit of a Rookie Mechanic to replace camshaft and lifters, any tricks or tips to look out for while doing job? should I upgrade anything while I am at it. A shop quoted me 2850 to do the whole job with AFM Delete. A kit would cost me 800-900 plus whatever else to replace for preventative maintenance.
