mrtahoe42
- Joined
- Aug 20, 2020
- Posts
- 44
- Reaction score
- 8
Yeah but it just the Hassel of running all that speaker wire to the backThe only new wiring that you will need to run is a power wire and fuse out to the battery for the new aftermarket amp, and whatever low level connectors (RCA type connectors) that you will need to run from the preamp out of your aftermarket head unit to the preamp in on your aftermarket power amp. Then, you will need to connect the speaker wires currently attached to your OEM amplifier to your aftermarket amplifier.
