help!!! put new head unit in 04 tahoe no sound out of two speakers!!!
foxridersc013
Bought truck used and it had a duel head unit in it and left front speaker wouldnt play or the right rear wouldnt either so i bought new head and wiring harness put all that in thinking it would fix it if i got the expensive harness and it didnt so trying to figure out what is up.all the tweeters are working though.
dropmech
Puddle Pirate
Coral Springs
Are they blown? The stock speakers are garbage in these trucks if it isn't a bose system. They fall apart after a few years.
F
foxridersc013
Not sure havnt had the door panals off yet but how would i test them?
---------- Post added at 07:31 AM ---------- Previous post was at 07:26 AM ----------
And if they were blown wouldnt they still play just sound like crap.these have no sound coming from them but the tweeter above the left front is working fine
---------- Post added at 07:40 AM ---------- Previous post was at 07:31 AM ----------
Are the speakers in the door connected to the tweeters in the door?
Yukongk
NY
Tell us more about your vehicle. Bose or non-bose? Factory sub? If you open your glove box, do you see an amp behind it?
zieglerj-pdm-specialist
in 100 degree sandbox
What I need to know is the Brand
What brand of Wiring harness did you use installing your radio. There is one install kit that if it has a milliamp jolt to it fries the box which is used for the Bose Amp , the door chimes and ability to use ONSTAR and use the Bose speakers. If you get the right wiring harness the Bose speakers sound great and the 8" speaker sub sound awesome for being in the front. But back to the wiring harness what brand did you use? I went through two of these wiring harnesses because I never disconnected the - battery terminal and I did that the second time and it was junk also. It was the $120 harness sold at Best Buy. If I hear the name of the harness I can tell you if its the junk wiring harness.
---------- Post added at 03:21 PM ---------- Previous post was at 02:59 PM ----------
I think It maybe ASSEX or maybe Pac as Odd as that may seem because PAC is a good brand but one of the two names given are junk. I installed a Scosche and it worked great and let the Bose sound like they are suppose too. The Bose speakers are not junk they rank with Infinity or Rockford and alpine speakers and the 8" even though mounted in the front bumps pretty good. I opened my mouth way to soon are you working with a Stereo with a Bose amp that takes a $120 wiring harness and it makes the door chimes work and the ONSTAR work or are we talking just about a regular radio with zero amps and two speakers not working. If its a Higher Dollar system with the Bose amp and sub, plus door chimes and ONSTAR I can help. If its a Redneck Truck with two speakers not working and your trying to get it working. Make sure the radio harness is soldered and hooked up securely and just take an old speaker you have in the house and wire the wires to that problem area and wire it up and it works, its the speaker most likely on both are shot, if they don't work then you have a problem from the head unit to the speakers! Trace the wires back to find a break or short or you could run new wires, which is much easier than chasing down a ghost. If this is a 125$ harness and bose speakers to work around than I can help you and the other scenario its just tracing or replacing wires?? I hope this helps/
F
foxridersc013
Sorry they were just blown the back are working now and its a non bose.put two new speakers in the back and both are working now thank for the help though.
ceramicdds
