help:Should i do a tune on my tahoe?
HK-DEMON-
Stockton CA
About 6 months ago i did a rear end replacement of the stock gear ratio to a 3:73 i believe, i cant really remember, anyways are you supposed to have it tuned after swap? and if so where can i get it done, im located in Stockton so anyone with some info will greatly be appreciated.
blueflamed03
Oklahoma
if you stayed with OEM gear ratio, no. If you changed it, your speed-o will be off.
TunasTwins
2005 Tahoe LS
Atlanta
Your ride will shift at the wrong RPM as it thinks the MPH is different. For the shift to happen it must meet three things: %throttle, MPH and RPM.
KrautBurner
Bremerton, Wa
so it's still the stock ratio?
90% of Tahoe/yukons have 3.73:1 ratios
blueflamed03
Oklahoma
if you changed ratio's, yes, have it re-calibrated for new gear or speedo will be off
Regulator23
