My ABS light just started coming on. It's off until I hit a small bump in road then it flickers. After the second bump, it stays on. ABS seems to be working fine (no pulsing or engagement at low speed)
Just before it started happening, I noticed a very slight slight drop in brake pedal but the light didn't come on. Light came on a few days later after a couple of more slight brake pedal drops.
I'd like to check and clean the ABS sensors but I'm not sure of the best way do get to them and not exactly sure where they are. Can someone point in right direction and describe process to clean them or post a pic?
Brakes are new. Power Slot front rotors (if this makes a difference). Maybe 2000 miles on new brakes.
