DevilDog
So i have a 96 Yukon, 4X4, 5.7 Vortec, 250000 miles, daily driver 100 miles a day. Last Thursday while driving I noticed the check gauges light come on and saw that the temp was red zoned, never overheated before. I pulled over and turned it off and heard the gurgle, after cooling off I checked and the rad was only half full. Topped it off and drove it home another 10 miles with mid range temp. After cooling off I checked the rad which was half again but when running there was no flow. The last couple days has been spent changing the water pump, rad, HG's, and all upper gaskets, since I know that these are prone to going out on Vortecs. Topped everything off, new antifreeze (green not dexcool, never had dex cool in it since I have had it), oil change, new plugs, etc. After bleeding the air from the system and letting it idle for a bit for gaskets to set, took it for test drive, when pulling out of driveway, it started blowing white smoke like no tomorrow, now it blows it even when idling. there is no noticible coolant loss from anything I can see and havent had to add any at all. Any ideas are welcomed, Thanks.
