retorq
The heads can crack from combution chamber temp but only micro cracks near the valve seat. Never seen a vortec head crack to leak coolant. And calve adjustment is simple.
If he ran it low enough that there was NO water in the coolant passage around the exhaust on the center two cylinders (4+6) where the exhaust valves are right next to each other and the engine was running under load, the jacket there will crack, it's not that thick.
Ok, thanks sunlit. Im going out there now to check and test everything again then go from there. Talked with a buddy last night who has a known good set of heads I can get if needed. But they are off an 89 model 350, and from what he says they are double humps. Thanks again.
Those will run like shit on a Vortec not to mention your intake won't bolt up.
Also every one of those head bolts goes into a water jacket, did you seal them all??
