Hello, I am new here but I am hoping you all can help me, I have a 1999 Chevrolet Tahoe LT 4x4 4-door with the 5.7 liter Vortec small block with 203,*** miles. I am currently replacing the intake manifold gaskets after a massive failure of the originals that it had, both were completely gone around the front water passages, which put all the coolant into the oil and circulated it through the intake as far back as the air filter. In any case I have the intake removed now and sitting int my garage with 15 years of carbon build up and oil and coolant milkshake all over it, I have the upper composite manifold removed and have cleaned it well, along with cleaning the sludge and milkshake out of the valve covers, but I am unsure of how to clean the aluminum lower intake without removing the fuel injection spider assembly. As the engine has not been apart before the spider assembly is original and thus has 203,*** miles and 15 years worth of wear on it and I cannot afford to replace it. Most sources I have read say not to mess with it or it will break, but I have to get the carbon and oil/coolant goo out of the intake and away from the spider assembly itself, so is there anyway to clean the aluminum of all the gunge without removing or harming the spider assembly?
Thank you,
Scott
Thank you,
Scott
