help with hid question
jwtahoe
hid bulb is to big for headlight housing had to use bulb that came with the assembly also one led bulb is not working there is a shield inside the projector which the bulb will hit even if it would fit in the hole help !
InTruckDesign
SW CT,
You will need to machine the hole out a very little bit, basically just cleaning it up. Then depending on the hosuings you purchased you will need to space the hid bulb back out of the housing to get a somewhat adequate beam pattern so the issue of it being too long is dealt with by doing so. The led light is probably just loose in its socket, I have had a couple that must have gotten bump during install and just had to re-seat them and they worked fine.
J
jwtahoe
ok i got the machineing part that makes senece but there is a shield inside the projector and what can I use as a shim and how would I lock it in place
THANX ITD
InTruckDesign
SW CT,
I ended up using a rubber spacer that was the same diameter of the base of the bulb. The spacer is almost 3/4" thick and I was able to use the wire spring clip that was on the housings, had to bend them alittle bit, but they are holding them tight. You may have to clearance a part of the radiator support directly behind where the bulb sits as spacing it out of the housing may cause the clearance issue.
