help with running 1/0GA Amp wire and also looking for G5s
blueflamed03
Oklahoma
your right, that's not very accurate, but with that much power, even the more reason to seal them...
V
Vicious00013
lol.. i just researched that meter.. it tops out at 130 and i didnt even know.. everytime i put a system together i counld get it pass 130 and im like WTF.. now i know..
So,.. when running the 1/0 gauge under the tahoe did you guys just drill a hole to get back in side or did you find a good groumet or something to enter back in threw
J-Will
#Merica
SW MO
if you drill a hole make sure you seal it off! lol thatll make a mess. we ran mine down the driver side. under the plastic panels and shit. wasnt terrible, but getting the plastics to fit after that has been a pain. one of em still doesnt. about the other subs honestly i love my l7s. theyre some monsters. im not a SQ guy tho. i just want shit to shake and fall apart. maybe its worth some experimenting? id say if you can get a good deal on ebay and build your own box it wouldnt be a bad idea.
matt14
san leandro,ca
I ran my 1/0 on the driver side door sill. There was a grommet for the gas pedal wires that i sliced a bit larger to fit the cable. Then removed the rear seats and ran it attatched to the back of the hump ( behind rear seats). It was a little bit of a pain in the ass just at that point, trying to make sure the cable doesnt get schaffed on the seat brackets. I also ran the ground the same way behind the driver side rear cargo panel, and drilled a whole in the rear tool storage compartment, and grounded to the frame. This was my first install in any car, and i personally diddnt think it was all that hard to run the cable. What kind of cable are you running?
V
Vicious00013
bleh,.. still need to decide on an Amp spot.. right now its under the back seat.. but I kinda want to take it all the way back and mount with the enclosure
tann808
Honolulu, HI
I just used welding wire, way cheaper.
FYI. make sure it has AWG on the wire, not all wires are made the same. I gotta show you guys some wire I had to compare (4 gauge vs 4 AWG gauge)
CHENTE
