Help with Sonar LED Taillights for 2011 Yukon SLT
Mattfox27
I have a 2011 Yukon SLT with the regular back door no hybrid and i want to order these Sonar LED taillights. They say 07-10 but will they work on a 2011?
I know they should fit but will i have problems with wiring? Does anyone have a pair of these can they explain how the wiring works? Is it the type where it has connectors like a male bulb and you plug into factory bulb socket then lock socket into LED taillight?
http://www.tunersdepot.com/Lighting/Tail-Lights--LED-Style-/Sonar--LED-Tail-Lights--Smoke----07-10-GMC-Yukon--Incl--XL-frasl-Denali--52824.html
soulsea
Administrator
Bar
They will fit.
And they just plug into your existing harness.
M
Mattfox27
Im just wondering because i had stupidly bought a pair of different ones off ebay that said they would fit 2011 and when i received them they fit but the wiring was these male bulb plugs that you plug into factory bulb socket then lock the factory bulb socket into the LED taillight. None of the bulb plugs worked and only the reverse light socket fit into the LED housing all the other sockets were too small and would not fit. Does this use the bulb sockets or do you unplug the sockets and hook into a different plug under car?
soulsea
Administrator
Bar
M
Mattfox27
Ya i just want to make sure because the ones i got would not work without heavy modification to both the LED fixture and factory wiring. It was so weird on the back you had holes for 3 bulb sockets then these little pig-tails coming out of socket holes that had plastic copies of bulb ends and none of it fit and it was all weird. You didn't just plug into factory harness it used the factory bulb sockets which was weird because they didn't fit.
These ones...didn't work with weird setup
http://www.ebay.com/itm/07-11-CHEVY-GMC-SUBURBAN-TAHOE-YUKON-TAIL-LIGHTS-REAR-LAMP-BLACK-SMOKE-1500-2500?item=110835085588&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D7003473338582810772
soulsea
Administrator
Bar
I think you dodged a bullet. :)
RydnDrty
Houston, TX
you really should get the black G4's...they look so much better....I have seen a real pic of those Sonar's, and to me they don't look to great...IMO
soulsea
Administrator
Bar
It's the link I gave you a couple of posts ago.
M
Mattfox27
Duh...Sorry didn't even see the link...thank you so much for your help...
