Helppppppppppp 95 yukon surge at idle after 10mins
retorq
Kingman AZ
Can't really check the FP on these units easily at home, that is what mine sounded like then I had a pin hole in the hose between the pump and the tank outlet though ...
C
cburns002
Well have changed the iac, egr, fuel filter, fuel pressure regulator and complete tune-up.... Checked for vaccumn leaks (none found)..... Slide underneath the truck and the fuel lines are rusty.. Trying to do everything and anything b4 i have to drop the tank.. Any suggestions....... ??????????
C
cburns002
lines are not leaking at all.. i have no way of checking the fuel pressure
BigWheelinBubba
Troy, MI
Sounds like rust buildup in the injector pods.
Next step, since you sound a little challenged in the repair dept. is to get a new fuel line ran and get a set of injectors off of ebay or something. Might even get a whole new or gently used tbi unit.
retorq
Kingman AZ
Since it's at the shop he should probably just let them fix it at this point and maybe post back with their findings.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
wait if you had no way of checking pressure why did you seem to imply it was good in your first post? at any rate leave it to the shop in its entirety since it is already there.
C
cburns002
Well have gotten the truck back and after changing fuel pump and sending unit.. Feed line to the filter, new strainers and line... Still having the same problem................................................... The shop had it for two weeks and still cant figure out the issue............... Hellllllllllppppppppppppppppppppppppp
ezdaar
Chat Troll
Redneck central, Aka Houston
So you paid out the ass for some shop to swap parts that was perfectly fine and your OK with that..
Since this got missed on the first page.
Have you checked you O2 sensors?! Do you have any Pre O2 sensor exhaust leaks?
