on the diagnostic connector below dash look at the top row of terminals and the right end the last two wires should be white/black and black white. these wires are right next to each other not a few wires apart. short the two together and turn key to on but do not start. the check engine light will start to flash. 1 flash, short pause, 2 flashes then a long pause. that means 12. you will see it flash the number 3 times. if you have fault codes they will each flash 3 times, if you have no recorded faults it will continue to flash 12 continuously.
