eanmizell
I have the spacers in
rear looks pretty dropped. I would cut the brackets off anyway will ride better.
lol sweet you were on a mission tonight lol.
If you need bumpstops just hollar i have the ones that you drill/tap hole and then they screw right into the frame.
works for your truck also
http://www.tbssowners.com/store/index.php?act=viewProd&productId=66
btw what does it measure both in front/rear from ground to fenderlip and also what tires on it?
looks like 34.25-34.5 in front and 35.25-35.5 rear
OH YOU just cut bumpstop. I thought you took ENTIRE bracket off the frame. If you do that you get 3 inches more axle movement.
btw you can cut the spacer in half if you wanted do drop rear end 1/2 inch
