Here we go again ...
soulsea
soulsea
Bar
We'll see ... if I get frisky I might sand the plastic down a bit to see if I can get them through there.
soulsea
soulsea
Bar
So I spoke to Bill over at v-leds, who's very nice and tried to help me out ... turns out that 7440 socket/bulb holes are the most inconsistent in the industry, ranging from 16mm to 20mm ... The tritons are on the upper range and the escalade sockets on the lower, so there's no way to make them work. One could hypothetically start sanding down the bulb access hole, but it would need to be sanded so much that there might not be any trim notches left to grab onto the bulb itself, and he advised against this approach. So they're heading back from where they came. :(
Not sure if the same issue will manifest with NNBS Tahoe or Yukon tails, but a measurement would be advisable before any order is triggered.
soulsea
soulsea
Bar
Got some more v-leds goodies yesterday, including these fog bulbs: http://www.v-leds.com/5K-WHITE-6-LED-DRLFOG-p9816978.html (they require a tiny bit of tab trimming around the bulb base)
I just put them on and I'll take some pics tonight ... the drl and park light are as you know a bit more difficult to swap, but at least for now the carpet matches the drapes.
Rochester Jim
