hesitation/stumble 95 tahoe
retorq
Kingman AZ
Not if you are using the timing light to check spray pattern no ...
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
got the timing light out tonight and from what i saw it didnt look terrible, there was fuel splashing the outside edges of the throttle body and i didnt see anything unusual but then again the light was so bright i couldnt see very well. i checked it under a solid light you could see a little ring of fuel shooting down every now and then on both sides. no big drops or anything, i put some seafoam in the tank 2 days ago, probably wont do anything, i dont really believe in any of that additive crap but who knows. it kind of does seem to be running a bit better. doesnt shake as much at idle anymore.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Chevron's techron actually works very well. It should preferably not hit the walls and puddle up before entering the intake on the way down. perhaps it is time for new ones.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
well im still fighting this battle... i put new injectors in last month, turns out last time i cleaned the old ones i put one in wrong:emotions122:
anyways, it seemed fine for a bit like always when i replace something, then it starts happening again, well now it almost seems like a miss every now and then and i noticed at a slow coast my idle slightly increases and decreases a few rpms rapidly.
i should really buy that plug in... so i can see whats going on
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
think i finally solved this one. i put a new distributor in, when i put the new cap and rotor on some how i didnt push the rotor down far enought and it was hitting the cap.. must have been a crappy cap and rotor before and my bad installation of the new one caused the newish problems, guess that explains it dissapering and coming back:emotions122:
runs fine now thanks for the help everyone
bullrunlover
