Hi from Indiana and a new?? purchase with a few issues I think
Scubadoguk
Hi as promised lots of questions no idea really where to start, 1st The service engine light is on, the autozone guy plugged in and found a ecm wiring code he said that could be well he had no clue but you get what you pay for I guess :) anyone have any ideas where to check or come across this issue?
2nd. Today the abs and brake lights came on, now Christmas is coming and the dash is looking festive with all these lights and colors on but I am getting concerned any ideas what could cause this , there will be other issues I am sure but these two are the ones that are front and center, the Vehicle a 2001 Denali Yukon 6 litre. 230000 miles.
Any suggestions would be great, Thanks
S
Scubadoguk
well what a dumb ass I am Mods please could you move this to the proper area sorry guys
about20ninj45
either you have short in the data bus, or you have a battery thats going bad. Id replace battery first and see where that gets you.
S
Scubadoguk
The main battery ? sorry used to bikes and small cars, so lots of newbie questions and clarifications
#1taho
5150TAHO
niagara falls ont
I don't know of any scanner picking up a short in a wire or even a "Ecm wiring code" .
Before you get further into this, have a shop scan it and start over. The battery idea is a good one , that is very possible. You have alot of electronics in you truck, if the battery is weak all your electronics will not work properly. It's a long shot but get a test light and check fuses, It could help too.
about20ninj45
No but if there is a short, the ecu can potentially throw the wrong code
S
Scubadoguk
So if it's a short is there a better test to try? is there a test even or is it replace the ecu. I suppose the only real way is to get in there
Dnozgodlike
