HID problem
danimalmax
louisiana
isnt there a slight bump on the factory part that prevents it from going into B1 anyway?
MikeTheApeman
The armpit of America - New Joisey
Has anyone here used DDM's Raptor kits? I've been hunting for HID's for my fogs, came across these, but looking for opinions. Also curious about you guys running HID's in your fogs - no issues with heat? Did you use a harness?
BTW, I'm rolling a 2005 Hoe with 880 fog lamps. Since they're only 27w, I'm thinking a harness might be in order for any HID install.
Krunchy
Krunchy
Chilliwack BC
When pluging into the balast from your factory harness... Flip the plug over. It's Chinese, everything in china is wired backwards...LOL I'm serious... Chevy's have the power and ground reversed in the plug....mine work good..
---------- Post added at 12:41 PM ---------- Previous post was at 12:38 PM ----------
ditch the l3-l4.... Hook factory to b1...
I will give it a shot you would think they would tell you to do that if thats the case
05Yukon
Houston
Some people may need to use it. It depends on the vehicle. You could use it if you wanted to but there is no point
danimalmax
louisiana
aftermarket kits (most) dont have the groove..they go in either way
mine wouldnt go in at all unless i cut it off
---------- Post added at 03:43 PM ---------- Previous post was at 03:42 PM ----------
No harness, no heat issues?
no, 35w 880s are right for fog housings, if u got 55w, then i bet you'd melt your fog housings
Krunchy
Krunchy
Chilliwack BC
Thanks a million that was the problem they work perfectly now
Smityinms
