High idle at start
nsmith
nsmith
What happens if you unplug the coolant temp sensor? Not the sender for the gauge but the sensor for the open and closed loop info to computer.
I’m ok at mechanics but that went, maybe the terminology, above my head. Is it just the fuse lol?
02 Yukon XL
Everything under hood is new~newer trans
CAI~headers ~flowmaster~billsteins~moogs
20’s on Nittos
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Thanks Tony.
GM can change things but that location used to be for the sender and the sensor was up by where the thermostat used to be on top of the intake.
As I look at RA for this they list a sensor but no sender. The two may now be all in one design. If you read the description though it talks about how it communicates with the computer to adjust air/fuel as it warms and even effects timing.
nsmith
nsmith
All my issues are with AC on. Would the sensor be messing with computer when AC gets kicked on?
02 Yukon XL
20’s on Nittos
afpj
What is a screen delete? if you remove the screen from the MAF that changes air flow characteristics. You also mentioned electric fans which are not standard on an '02 Yukon. Did you have someone do a tune on it?
nsmith
nsmith
It was an eBay kit that hasn’t given me any issues in 3+ yrs. I have a temp probe that tells them to kick on and then wired into AC when AC kicks on they kick on. Screen from MAF is deleted. But no issues in 2+yrs I’ve had that. My issues seem to be with AC on only. I’ve done some reading up and replace temp sensor and see if that makes a difference.
02 Yukon XL
20’s on Nittos
Allthingschevy12
