high output alternator
dre
About to purchase a h.o alt. ......Is it true that the ecu controls the voltage. or something to that effect. please enlighten me. thanks for the info
chip
Tampa
Good question!
My advice would be to ask the seller of the alternator if it's internally regulated. If the seller can't give you the correct answer, buy from someone else.
ScottyBoy
Shreveport, La
Someone asked pretty much the same question on another forum. Supposedly the 07+ trucks are regulated by either the PCM or the BCM. 06 and older trucks are not.
The guy was asking if the voltage could be adjusted with a tune, and Jenna told him no.
Adam1986
