High pitch noise from speakers as i accelerate
NoPh33rRaCiNg
Kent, WA
lol naww im not goin to an audio shop.. damn thing is stock.... i noticed on one post someone said could be a bad diode on the alternator.. im gonna go that route
pull out the stock deck, and look on the harness for the black ground wire and reground it to a solid piece of metal in the dash. see if that helps
Thumper8302
OKC, OK
ill do that when i swap over my old system.... i only drive maybe 10 minutes a day so i only get to listen to like 2 songs at most.. but i pulled into work today and was makin a turn into another park lane and the truck just up and died.. just got home and noticed when i let off the gas to coast the lights dim a good deal. rpms drop around to maybe 300 and voltage drops to about 9... im prolly gonna go get the alternator tested tomorrow.. just dont wanna shell out the $200 for one... Hell i havent even got my title yet.. oh well.. gotta love swipin the plastic when ur in need.:emotions122:
oh and hey blueflamed03.. where bouts in oklahoma u at? im in the nw side okc
Thumper8302
OKC, OK
i used to live in stilly a while back... worked at the get n gallup there on lakeview and perkins once upon a time lol
Thumper8302
OKC, OK
lol yep small world it is... i need to plan a trip back to stilly.. havent been in a while..... im cravin some shortcakes lol
lyukonr
los lunas, new mexico
hey guys, im having the same problem too, but on mine only stops if i turn off the unit, its really annoying :emotions122:... i have one of does adapters for the bose system tho, when i put the oem radio it stops, i allready tried like 3 diferent aftermarket radios and it still sounds, could it be the adaptor??
kickitandholdit
GA
my old tahoe did that untill it was slamed into another truck it was purdy quiet then haha
yargnits
Northern Indiana, the land of annoying lepreachons
Even though I'm suffering whine problems with my truck I can give you a place to look. It sounds like the same problem I had with my 91 Caprice a few years ago. Try unplugging the antenna. If the sound goes away it's a bad antenna or a coupler in the antenna wire. Caprices had a coupler that corroded causing the problem. I re-coupled it with better connectors and the whine went away.
It might not be the solution but it's worth a try.
Kooter
