High Pitched Noise from Front
MasterHank
I have had the same thing, happened just yesterday lasted about 4-7 seconds usually when I just shift into gear, I will check the cap on the cylinder and look for visible leaks
and advise, It has happened 4-5 over the last 3 years.
also had an issue with the windshield wipers not working, Wife had taken the truck out called 10 minutes later in a panic said they would not work but the lights would turn on and off
read a few posts people changed a board etc
the solution I found was turn on the lights all the way from off to on with the engine running then turn on the wipers then it reset itself.
also had an issue where the door locks would lock unlock while I was driving again people changed control boards, but the failsafe with this truck when the remote battery is weak it auto unlocks so you can drive the truck disengages the anti theft.
bobwass
