When looking for hoses on rockauto the description states for a 1-piece or 2-piece gearbox and 2 diff designs of the box.Anyone replace their line? Mine has been showing signs of wanting help. I have a repair manual but did anyone run into issues?
Is it pretty "decent" repair?
I see hoses are only $15-20 or so.
Thanks for the reply.So here we are again with someone wanting help and not supplying any vehicle info. See below. We would need the RPO code for the steering gear box options. Hell, I don't even have your vehicle year so I can at least try to look up hoses and RPO codes. C'mon man!
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
^^I would recommend going to a gm parts dealer site like gmpartsdirect.com, enter your VIN, and pick through the categories for the part you need. They're not always complete, some parts have been discontinued or may not be shown, but you may be able to get the part # for the hose, or the steering box part number to crossreference at a site like Rockauto, Amazon, fleabay, etc.
So I found out that the gear housings are simply, as stated, 1-piece or 2-piece. Its as simple as 3-bolts holding on a small housing at the steering shaft end that determines the "2nd design" version as listed on rockauto. Duh. But I didnt want to assume anything.
SO I now know my part number for the high pressure line.
When it comes to the return line.....has anyone used general power steering line (un-molded) and attached it to the $5 fittings available and if so how has that worked? I assume the molded will fit better and sometimes that molded version is the better way to go to eliminate issues. Power steering hose is stiff IIRC. But maybe I am wrong.
I don't see paying 25 for molded when $5 for fittings and 1.25/ft for hose is available????
Thoughts?
Thanks.
