High pressure power steering line
N
new2yukon
That return line is molded for a reason. Spend the $25 you cheapskate! LOL!
Haha. Well if I do one line to the cooler I might as well do the other that returns back. And THEN I see the whole assembly with new cooler is 60-ish and so I may just buy whole thing.
Gosh. 50 in 2 molded hoses and fittings or 60 for it all set to go in asm?
That's why I'm asking. Sounds like I'm doing the 60 asm most likely.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Good call. If either hose has a spot where it has a strap that holds the hose in place make sure you reattach it.
wildcatgoal
If you have a 4WD, you need a certain line. If you have a 2WD you need another. The 4WD line doesn't have a loop to go to the back of the power steering pump because it connects to a variable steering valve extension that terminates under the steering rack.
N
new2yukon
Mine is 4wd and the line appears to connect on back of pump but maybe I'm not seeing something. But I'll look deeper on it.
wqshaider
