How do I adjust healights?
rolfsent
Cincinnati
Just replaced all the lights on the front of my 99 Denali with DEPO turn signals and headlights. I assume the two star things on top of the lights are how you adjust them, but when I turn them nothing seems to happen. Is there a trick to this or am I just not doing it right?
bowtiefreak
No Quarter
Near Philly
The adjusters could be broken or maxed out one way. I'd pull them out and double check to see if they work
Freedom Motorsports
X2, they may be broken, pull them out and check while they are out of the truck to ensure they are actually moving with the adjustment.
rolfsent
rolfsent
Cincinnati
I ended up figuring out what was wrong, the one bulb wasn't all the way in the housing. Not sure how it came out lol. The difference is amazing at night, especially with my SilverStar Ultra's.
rolfsent
rolfsent
Cincinnati
SunlitComet said:
you think those are good you ought to try hids.
I had HID's and I had too many problems with them. I had them working for about 3 months and then after that it went from 1 headlight working to none. I tried everything to try to get them to work and I couldn't fix it so I just pulled them out.
95escahoe
I run the same headlights/turn signals on mine and love them got the crystal clear head lights and blacked out turn signals
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you sure those were the adjustment screws and not the retention bolts the hold the housing to the bracket? Horizontal and vertical aiming of each headlamp assembly is done by two adjusting screws. The screws are located within the radiator support, and are not easily seen. Two holes in the radiator support for each headlamp assembly provide access to the recessed adjusting screws .Turn the screws using a T15 torx head bit. I know you have it fixed now but though it might help in the future.
rolfsent
rolfsent
Cincinnati
I'm positive it was the adjusting screws. I know which is which. I figured it out now
Donnie Yukonie
Yates Caretaker
I was gunna say what sun said I thought as well that they were adjusting screws until the headlight fell out of the grill one night lmao:)
Sent from my iPad using Tapatalk HD
Tssonebay
