JesusArTorres
I had this installed some years ago, but I removed it a couple of months ago. Now I want it back in, but don't know how to connect it. Some wires seem obvious but others don't.
Red = Batt +
Black (larger) = ground
Black (with blue) = remote
RCAs = obvious
2nd pic = no clue LOL. Shoulda labeled those.
***shoulda taken pics prior to taking it out***
Look under the hood for a fuse, remove the fuse. Then hook up the Red, black and Blue.
Hook up the RCA's then grab your speaker wire and see if it is marked with a line or symbols or something, and make sure you connect it the same way at the sub and at the amp. IE: wire with a line goes to positive speaker output on the amp, and the red terminal on the sub. the negative on the amp goes to the black terminal on the sub.
Thanks for the info!
After some googling, do I pull "Radio 15A" or Radio/AMP 30A"?
