Ducati18
How much boost can you run on a stock motor?
I am currently running right around 11psi.
I've seen some people run 12psi w/o any probs. But I've also seen people run 8-10 psi and throw rods, blow head gaskets, etc. A lot of it will depend on the tuning to make sure you aren't detonating or running too lean. If the pcm tuning is spot on, you should be able to run 10-12 psi w/o any probs. A lot of it will depend on the mileage and condition of the engine and proper pcm tuning. Even on a new stock 5.3 LSx and a dead on perfect pcm tune, I personally wouldn't run anymore than 12-13 psi just to be safe.
Its not about how many psi. Picture a very small turbo, it will flow a certain CFM of air. For simplicity lets just say 10. Now a bigger turbo can flow up to say 20. It might take the smaller turbo 10psi to flow the 10cfm of air. While on the bigger turbo at 10psi it might be flowing more air and making more power. Thus depending on what turbo size you have, determines what power you theoritcally CAN "flow".
So dont confuse PSI and HP. HP kills motors not pressure from the turbo or blower also tune has a lot to do with this. avoid detonation..
I am getting it tuned next month. So i figured that I would change my pulley before getting my tune. Do you know the pulley size that i would need to get to acheive that kind of boost?
Are you running the 2.9" or did you pulley down again?
