How much prep work before Painting?
James417
Hyde Park NY
Hello all again. Got some update pictures on my floor pan project in my 2003 Tahoe. Showing how I removed seats and took out new floor pan set on to of old rotting one one and cut the rotting one out. Been doing tons of prep work by grinding and wire brushing and using Naval jelly Phosphoric acid and will be using a more concentrated phosphoric acid I have for restoring gas tanks Ect then painting with self etching primer once to bare metal then after a few coats of the primer painting the red code paint on top then roll on some thick truck bed coating. How does the preparation look like its coming along? Just wondering how far I should go before I start painting. There are a few areas where the original paint wont come off as well as the pitting and the bad areas of rust are turning a dark color after phosphoric acid treatments but not going down to shiny metal. I guess that's from bad pitting and rusting on surface but you will see in pictures what I'm talking about. Also please ignore the rocker panel rot pics that's after chisling loose stuff out. Got to cut that out and weld in a new one but that's a summer project just got the loose stuff out so I can get in there and rinse the salt and sand out during the winter. BTW that plastic barrier that goes behind the accel and brake pedal up the firewall is in the way a little so I had to lift it I wish I could take it off but don't have the money (for busting clips and parts) to take the dash apart at least I can still work around it though. LOL Anyways thanks for any advice ahead of time.
Pictures:
https://www.flickr.com/photos/87811337@N02/
J
James417
Hyde Park NY
Thank you! I am trying my best to get the floor pans ready to last a long while. I'm actually doing some more treatment with the phosphoric acid now but I notice there are areas with some scale and pitting still I can't get down to bare metal. Maybe need an attachment fr grinder or drill to strip it off?
J
James417
Hyde Park NY
Yeah I know what your saying. Without proper prep the paint will fail and rust will come back but while I was working on this truck it finally struck me how much work I'm putting into it instead of driving it. Been almost 2 years waiting for the title and now I'm doing more work and prolonging being able to drive it. So I decided to do the best I could with the phosphoric acid and wire brush and now I am applying the self etching primer. So wish me luck with the primer staying. Then the red base coat then some thick truck bed liner.
PinkAle
Maine
Awesome job my only concern is how much metal did you remove to achieve the goal of getting to bare metal as you don't want to create weak points in the structure. I would consider consulting someone who does welding
J
James417
Hyde Park NY
Thank you I am red trying to get it well painted and hopefully prevent rust from coming back. But I see what your saying. I did cut out the whole pan but I also cut above where the pan was spot welded onto the body and then chisled the rest of it off the body. So I don't think it's causing any structural integrity issues but I will definitely look into that. Thanks for the heads up. Used naval jelly then cleaned that up and used a more pure phosphoric acid on the driver's side pan and got my first 4 or 5 coats of primer on. It's a little ruff but I got all of the loose stuff off and got the rust and scaling off. So next is to work on other areas and passenger side then then hopefully it will last a while. Lol
J
James417
Hyde Park NY
Gonna be posting some update pics on the painitng but I have got all the priming and base coat done and about 2 hours ago clear coated everything. How long should I let the cost coat "dry" before I put the truck bed liner on and installing the floor pan? I know that clear coat can take weeks even months to fully cure but how long until its safe to out down the rubberized liner? Only putting this on the pans themselves to help with wear.
Thanks
Mpriest
