How often to change Synthetic Oil.
HMFDZ28
Hunt Sta, NY
I have the RP filter on both my Camaro and my truck and havent had an issue with either.
As far as when I change my oil... I follow the mileage (its usually around 5k) and oil pressure. When I notice my pressure is lower then I like I change it; I think thats the most important. I like the needle on my truck sitting round 40 psi at idle... and so it shall stay.
Cobra
Austin, Tx. area
I always tought the computer was set around 7k. Either way I currently running Mobil 1 full syn. and still stick to 3k to 4k. Usually closer to 3. I know I can go longer but just prference.
Abn Panzer
3K-4K... Out of Habit
I've allways kind of floated between the Synthetics, depending on what was on sale at the time.
Had also been using the K&N oil filters... that is until last night when I read the Filter reviews, posted earlier in this thread. I am aparently a sucker for advertising and 'recommendations based on ignorance from some sales people'. Anyone have a bridge for sale?
Z15
Michigan ,USA
No its not based on mileage or sampling of the oil. Its a computer algorithm that takes in account engine starts, rpms, engine temps and other factors determined by years of testing, in other words driving habits. The more stop and go driving you do, the sooner the OLM will trigger, drive all highway miles and you could go a year and more than 10,000 miles before that happens. OLM are only calibrated for synthetic oil in car that come factory filled with synthetic oil like all Cadillacs since 2005, all Corvette's since the early 1990 and starting in 2011 models you will be required to use a synthetic.
How much oil is lost changing just the filter, a qt or less.
People really think that If it says full or fully synthetic on the bottle that they actually really get a real synthetic oil in this country . All the oil company synthetic's are derived from petroleum base stocks. There are only about 3 main companies making a true synthetic. That is an oil engineered molecule by molecule rather than refined by a special process call hydro-cracking.
Why do they call them synthetics then?
In 1999 - Mobil filed a complaint with the National Advertising Division of the Better Business Bureau in the US claiming that Castrol was engaging in false advertising by calling Syntec "full synthetic" since it was now being made with Group III base oil. (Google it you will find its from petroleum.) Castrol was able to present enough "evidence" to convince the *** that Group III base oil could legitimately be called synthetic, so they rulled in Castrol's favor. This ruling has no "legal" standing. It merely means that as far as the *** is concerned, an oil company is not falsely advertising an oil as "full synthetic" if that oil is made from Group III petroleum base oil. So in other words, the oil companies are using the term synthetic to sell you high priced petroleum oils. They might be better than oils that preceded them buy still are a long way from the true Gr. IV synthetics, some which have been on the market since 1972 (AMSOIL).
redemn93
Jupiter, Fl
so is mobil 1 full synthetic?
i go between mobil 1 and penzoil "full synthetic".
once i get change oil message in my 01 tahoe i look at the oil. its usually still clean so i wait a little longer. if oil pressure is good and the oil is clean...its still good oil.
Z15
Michigan ,USA
No, those 2 oils you mention are a Group III synthetic. All the only company synthetics are Gr. III base oils. The only Mobil oil that is a real 100% synthetic is the Mobil 1 Extended Performance oil. The term Full or Fully synthetic is the tip-off, they will never say 100% because it cannot be and still come from refined crude oil.
Of course you are going to get a awful lot of arguments to the contrary from loyal Mobil 1 users and others who have limited knowledge of oil formulations. Real synthetic oils are not cheap to make so you will not find them selling at discount prices.
Hydrocracked/Hydroisomerized = API Group III base oils. Chevron, Shell, and other petrochemical companies developed processes involving catalytic conversion of feed stocks under pressure in the presence of hydrogen into high quality mineral lubricating oil. In 2005 production of GTL (Gas-to-liquid) Group III base stocks began. The best of these perform much like polyalphaolefin.
Group III base stocks are considered synthetic motor oil ONLY in the United States. Group III based lubricants are not allowed to be marketed as "synthetic" in any market outside of the USA.
redemn93
Jupiter, Fl
good info. thanks. i still like my mobil 1. my engines are always so clean when i open them up for one reason or another.
so i guess, theoritically, fully synthetic oil will one day be cheaper the mobil 1, etc as crude oil prices keep going up.
Z15
Michigan ,USA
The oil might be synthetic but the energy used to produce it and to transport it is not so everything hinges on the price of crude.
Tdub
Is it okay to switch over to this oil if you have 140k rounds?
07Denali
From all that I have read, yes. But, do not go back and forth. Change to synthetic and stay with synthetic. The only thing that I do remember is that I was always told to "break in" motor with regular dead dino as the rings need it to seal and seat properly.
I am by no means a petroleum engineer, just what I have read from all those that are supposedly smarter than I am.
I run 0w-30 Mobil one in all of my cars/trucks. I got turned on to it by Toyota as that is what is in the Lexus and that is what you have to use to keep the CEL off. Any heavier and they insist that it will slow the valvetrain down and cause the light to come on. I got an updated maintence manual in the mail from Toyota right after I bought the car new and the only change was taking the oil change interverals to 10,000 miles. I change my car myself at 10,000, 95% highway miles, and most people I know (even car guys) would take the oil and put it right back in, it is that clean.
CaptPat
