How to clean my engine?
gdddup
NJ
spray everything with a degreaser like purple power, spray 9, simple green,etc. scrub the real dirty spots with a brush or wrag. then blast with a hose. then pull out a air hose from the compressor or leaf blower to move some the water. final step is to spray everything with some glossy shine stuff like armorall black magic or stoner
DTAILS
If you have air a some decent water pressure:
Spray with degreaser
Let sit for a few minutes
Pressure wash (at your own discretionn)
Agitate with a medium bristled brush as needed
Rinse
Blow standing water off of surfaces
Spray with dressing (CG BareBones is my go-to)
Blow excess off of surfaces
Let set for about a half hour or so (time enough for hoses/plastic to soak up dressing)
Wipe up with MF towel for final touches
Old pics, but decent idea given following the process above:
stevek
Dallas, TX
For the block, spray simple green. Sit for 30 minutes. Rinse with low pressure. Repeat once. Third time, spray the simple green and scrub any parts you can reach or that need to be cleaned. Works like a charm
dwmmatt23
central valley cali
Ok so my engine is super dirty and greased up, I was going to clean with some engine bright foaming spray and diluted simpled green with soft bristled brush, however after talking with several tahoe/suburban owners about water damaging knock sensors and getting into unwanted places on our engines im a little leary of spraying down my compartment. Im I just being paranoid?
DTAILS
Yes.
DaRosa218
The Dude abides
Modesto, California
Mine was drenched in Clay and Mud from a little off-roading at LaGrange a while back ago. I decided to clean my engine with some Engine De-greaser and Water and now I have a constant CEL for my knock sensors. It's probably my dumb luck, but it happened to me.:imo: :Handshake:
A Little fun making the Engine Dirty :)
juantavarez127
