How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
Narco
Atlanta
im putting the ss bumper on so ill be losing my fogs. so if i understand this right, i would only need to do the 4 high mod correct? the 6 would be a waste. no?
DenaliAK
Colder than you
Alaska
Correct. 4-high will be all you need to do.
PUNKYOU007
Hopewell VA
Any chance i can get a pic of said yellow wire to ground
---------- Post added at 12:20 AM ---------- Previous post was Yesterday at 11:51 PM ----------
Nevermind, I see now.
man your such a NOOB
hassoun
Germantown, MD
so i did the 4 mod on my 01 denali by grounding the yellow wire on the low beams. any suggestions on how to get the 6 mod done on my denali ? should i ground the fogs too ? or maybe wire them up to parking lights ? if so can anyone walk me through instructions ? thanks!
highrollin113
Undercover
Edmonton, Alberta, Canada
does anyone have two extra laying around and want to do me a solid and mail me two i cant seem to order to canada from the radioshack page and "the source" our old radio shack does not have the 3amp and want 4.99 for one anyway compared to 1.49 for two
Abn Panzer
Silly question... But Not knowing makes me nervous.
Would there be any problems if I shaved/sanded the ends of the diode's 'wires' to be thinner? I've seen where people said to jam them in, and someone flattened theirs with a hammer... what about sanding them narrower? Is there any issue that arrises with being thinner at the ends? or shaving off the outer coating of the wire exposing the copper core?
May be an obvious answer to some... just not me.
blackbeast03
NC
I just did mine, took all of 5 minutes. radio shack was out of the 3amp ones though, so i used a 200v 1amp, hopefully it lasts!
