How To: Hidden Antenna Mod
Yuko04
"SquareBODluvr"
MN
Just did this mod....sweet! Did it the way 05Nali did it and i pull more stations now than I did stock:gr_grin:
jdpber
GOLD MEMBER
The America
i would so do this mod.. BUT i use my antenna as a feeler gauge in parking garages if antenna hits.. the ceiling is only an inch from hitting my roof rack.. so antenna stays.. :(
mykon04
Porter, Texas
Man with all that lift and everything I wouldn't even try to go in a parking garage...:)
BaMaDuDe87
Bama
05's pics are gone now so Im curious, but you guys just unscrewed the antenna. Cinched a wire on the threads and ran it up the weather stripping? Didn't unscrew the base?
BillBlatt18
Latham, NY
Ill put up new pics tomorrow if they aren't working for you. What I did was solder the copper wire to the base and then ran it up behind the weather seal. So no, I do not unscrew the base
TacHoe
DC
For those of you that ran a wore in the weather strip, what size nut did you use on the antenna mast to secure the wire?
I am wanting to know this as well but for a different reason, one I haven't seen to this point ANYWHERE on here :naughty:....
Will fill everyone in on it if I can find out the size of the nut that screws on top of the threaded base piece
TailHook
Tattooed Millionaire
Arizona
When I did this mod, took the antenna to a local hardware store and found a bolt with matching threads, then bought the corresponding nylon lock nut. Can't remember the specs, it was so long ago...
Reyes1987
