How to: make NNBS LTZ rear headrests adjustable for baby seat
04ctd
Charleston SC
if You have the electric release rear seats in your LTZ, the headrests are STUCK in the low position.
you can barely force the rear tether/anchor strap under the OEM headrest.
most women can't, which means the Dad has to push it through.
if you do get it through, it feels like it will rip the dickens out of the pleather when you pull it back thru.
to take the OEM NNBS rear headrests off, there is a tiny hole on the trim cover.
(you do NOT have to take off the black cover, I just did it for pics)
use a small punch, and press in the release.
the odd part is they face the same way, so one is facing out, and one is facing in between the posts.
i marked off an inch down, and put some tape on it
you could use a peice of black tape to mark it down about 3/4 an inch.
to put the tape on the post, wrap it backwards around the ruler, then align it, and wrap it
used an air grinder, the blade is the perfect size.
here is the OEM picture:
here is the pic of the headrest one inch up:
all the pictures
http://s19.photobucket.com/user/04vrscb/library/NNBS_headrest?sort=3&page=1
the caveat will be, you will need to slide the front seat up to allow the headrest to clear, so the seat can fold & tumble forward, but you have to do that in an LT anyways, so IDK.
IMO, the electric release is just added weight to hurt MPG, and something else to break. the button is in such an awkward place, it's easier to use the manual handle, however....YMMV?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Awesome! I moved it to the "tech section" with all the other how to's!!!
:waytogo:
08grey
The denali uses a smaller headrest that is adjustable for the automatic seat. Check one out it may suit your needs not the best picture but you can see the difference in size. ImageUploadedByTapatalk 21372367346.848215.jpg
04ctd
Charleston SC
wow...those are much smaller. i wonder if it's because they have the DVD in there?
my rears look as big as the fronts, in the pics..
08grey
I put those tv's in myself. They were smaller regularly. Probably because the seat auto folds and is not supposed to get caught on the seat in front of it.
the42-th
Moscow, Russia
Thank you, 04ctd, you really made my day! I had to drive my wife's car, because I hate to get the ancor under the headrest! I already checked my truck, now I only need to find a grinder :). I wonder if the plastic cover on the front seat is the same, so that I could make the headrest fully adjustable.
sanco
Chicago
great info, god this issue was driving me crazy, ill definitely have to give it a go
stking
