How to: rear part of BellTech 739 lowering kit
mikdiazz
hey tony, i just loaded my truck pics, igot your tbsspecial 4/5 and the stabilizer bars 9910, i replaced the parts at the end of august and the back has been getting gradually very bouncy, it bottoms out a lot now, the front maybe a bit outta alignment but other than that good to go.
in the back i checked for that piece of frame that i can cutoff so it stops the bottoming and i see the passanger side swaybar endlink broken also noticed that on your website the shocks with the kit are Belltech and you sent me be DJM,,,, its very shotty quality ride on the back, are the shocks a big difference??? and how much is that endlink and rubbber bushing?????
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
few things
1) did you cut the bumpstop brackets off the frame if not that is where the bad ride is coming from
2) about 1 month ago i switched to the belltech tb rear springs/belltech street performance shocks due to the new version of the tb springs from belltech and i feel that new design is a better ride.
3) in rear looking at the pictures of the swaybar it looks like the bar wasnt moved over 2 inches like the instructions shows. also the swaybar should be on the inside of the drivers side endlink and on passengers side it should be on the outside of the endlink this is the reason the endlink broke due to installing it wrong with it will hit the frame and snap the link.
here is the instructions you can see you installed it wrong
http://djmsuspension.com/Instruction PDF 0908/Kits/RK2000.pdf
Shoot me a pm and we can go over the correct way you should have installed the rear kit so we can address the problems you have because the link will break again if installed wrong.
Daddyyukon92
