Hvac control and dome light questions
ThwopKing
Bunker Hill, WV
OK so does anyone have a Dorman part number for the rear a/c control that sits above the rear view mirror... cannot seem to find it even though I'm pretty sure they make it... second... the done light in the center of the headliner... is it held in with screws? The front part i could pull down, but the back of it I felt like I was going to break if I kept pulling on it. Pics to show what I'm talking about. 4d663c90c4ef412ad33aceb1bc0d3beb.jpg7341248aa498ca82297f23453c105b3e.jpg
Sent from my SM-G973U using Tapatalk
PG01
Up here to the right
Pretty sure if you pull the light lense, as if changing a bulb, you’ll have a few screws up there.
ThwopKing
ThwopKing
Bunker Hill, WV
Well I figured the OEM part might be a lil expensive but after put it all back together and minted it back up... the panel is lighting up like it should lol. I also added some sound deadening to it while I had it out. But I'll check for those screws under the lamp lens for those screws. Thanks guys
ChevyBoi19
