HVAC controls not telling blower to turn on, intermittent
02Lightning
unless there is a hvac code saved then that one is going to be hard to track down until whatever it is just quits period.
Only pending code I see is a B0433, but I don't think it's related and not a hard code. Next thing I'll do is look at the plugs and try and bend some prongs for better connection.
Like every drive? once a week? how often, maybe hook up the tech2 and command the fan on high and see if it changes while driving. not sure if you can drive record the fan speed
@swathdiver ?
Should be able to using snapshot feature.
Have you guys checked those little aspirators in your headliner? They can get full of lint/hair and stop reading correctly which will confuse the climate controls.
02Lightning
How do you go about doing that?
If asking about the aspirators, pull the little speaker covers off and have a look up in there. Use a pick, Q-tip- vacuum cleaner, etc. to clear the fan blades if they are clogged. If the fan is dead, you can drop the headliner a little and replace them from the side. @Doubeleive Wes has more experience with these than I do, I think!
Rochester Jim
