Snowbound
Jim
Picked up driveshaft this morning.
He asked what I painted the shaft with because it wasn’t like any other paint he wire wheeled off. Haha. I told him, it’s POR15, it’s not meant to come off. He said he got it but it took a while and he only removed the paint on the end where he had to weld. They slapped on some sort of coating, it’s soft like an under coating. Looks good though. Cost me $172. Whatever. Put it in and topped off the transfer case because when I had the front of vehicle on stands, I couldn’t get the full amount in. So with front on ground and on stands in the rear, I topped it off.
I did the fast learn but it failed on first attempt. Let it sit for 5 minutes and then reset the learn process and did it again. Took the second time thankfully. It does all sorts of crazy shit while going thru process. Sorry, my GoPro was dead so I didn’t record it. But what it does is fill the clutches thru the gears, bangs and whines and the RPMs raise then lower. It’s strange but it cuts down on the time it takes for the trans to learn how much fluid it takes to fill the clutches. Then after it completed it won’t go into gear. It’s neutral no matter what you select. So I’m waiting for it to clear and then I’ll take it for test drive. I need to go thru emissions today because the damn license plate sticker is expired and I can’t get a new one until it goes thru emissions but because I’ve had the battery disconnected, I need to drive it so it goes thru drive cycles so the ECM can check all the emissions crap before it’ll pass. But I’m on the home stretch and I can almost call this chapter done. Thank god. Back to my sled!!
