I’m being told my engine is bad
tedv
South Florida
You're going to say that I'm crazy, but shortly after I had a rear main seal on my 2000 Suburban repaired, I developed a knock that sounded like a loose rod. Actually, I found one of the crossmember bolts' was loose and rattling. It was easy to check and repair, but it took me a month of running to shops and finally I crawled under and smacked everything I could with a mallet until I found it. Check and make sure the nuts on that crossmember are tight to the bolts ... think there are four of them.
TahoeFL2017
Thanks for that swathdiver
And thanks I will try the what you guys suggest with the catalytic converters
So I parked the truck Wednesday night around 1 am and have not drove since so it sat for about a day and a half and this was a cold start Friday morning. Again sorry it was just a quick video before leaving to work in a different vehicle so I rushed the video
Oddly enough this time when revving up the engine it did not really make the noise but on Wednesday when I showed it to a few people the noise was there every time I revved the engine. I may have to wait till Tuesday till I get it into a shop.
I had a old chevy motor that threw a rod, after 3 months of driving it knocking, I'm thinking its the flex plate or cats, does not sound like bottom end. Old beater trade-in that I bought to give to my brother for $150 bucks, temp transportation , we knew it would blow up eventually.
My rod knock sounded loud, and speeded up and slowed down exactly equal with revving the motor. Sounds more like something came loose and is bouncing around in there.
tedv
South Florida
2004 Tahoe z71 4x4
175k miles
Owned it 1.5 years
Got it with 149,500 miles
Has had a minor leak since I got it (was lied to about no leaks)
I used Mobil 1 5w-30 full synthetic high mileage and changed oil religiously every 5k miles along with Mobil 1 m107 oil filter
Always kept an eye on oil level and topped off if needed. Maybe a quart or slightly more every oil change
Engine ran very strong the whole time of owning
Without any signs it has developed a clunking sound on startup. This all happened in the past two days. Actually I had the oil changed yesterday and coincidentally it got way louder after the oil change. Before the oil change I barely noticed anything and I wasn’t even suspecting anything really.
On cold start it is very loud. Clinking/rattling noise. I was told by 2 shops it’s the bottom of the engine. Both shops were confident that that’s what it is. Then there is a junkyard across from my work and it took it to him for a third opinion and he says he’s certain it’s the flywheel that’s cracked. I called one of the shops back and told the guy I’m not going against what he’s saying but I asked him the possibility of it being the flywheel. He said that’s the first thing they checked, he said they removed the cover and all the bolts or screws where there? Not sure exactly.
I tried posting a video through YouTube but for some reason it won’t download. It just keeps saying processing. I tried posting a video directly on here and it says file too large. I’ll try to figure out how to get a video clip soon. I know not much you guys can go by without a video and still hard to diagnose by video as it is but would like to got some opinions
Also is there anything else I should have replaced if I have them do the swap. Both shops are suggesting to get a used engine to throw one in.
First shop say he located one with 113k miles from a guy that they do business with regularly. He want to charge 2,500. Not sure about warranty with him but he said he’ll go through the whole engine before installing and replace any manifold bolts of broken, plugs and what not
second shop said between 2,000 and 2,500 not warranty and can’t promise leaks or anything.
2004 Tahoe z71 4x4
175k miles
Owned it 1.5 years
Go read my post about checking crossmember nuts and bolts to make sure they're tight. My 2000 Suburban made the same sound as yours is making and one of the crossmember bolts was loose.
Scottydoggs
NJ
just so we all know. a rod knock will never just stop and start again. driven long enough its not a knock any more its a bang, hard bang you can feel. the more rpm, the more banging. i drove my 77 gmc with a rod knock for months, till i scored a used engine, it was so loud. i mean loud, cant even talk over it. so id do a lot of getting it up to speed and toss it in neutral and coast as long as i could. i was really hoping the rod would give out and blow through the pan or block, but she held up.
Michigan
Michigan
Thanks again for all the help.
Little update but problem not solved yet
I haven’t drove the truck since last Wednesday (exactly a week)
So this morning I started it up, no noise at all
I drove it to a nearby gas station that has a garage there, about a 4 mile distance from my house
Made no noise at all on that trip even when arriving so I thought great this might be hard for them to check for the noise when it’s not there
I planned to have the guy to lift it and check for the crossmember bolts (I know I should be able to do this myself) also I let him listen to the video and he agrees that more than likely it’s the flywheel (flexplate)
Anyways he said to just drop it off one day.
So I left and I work about 24 miles from there, first intersection I came across I made a sharp right turn and I heard the noise for just a moment
Now that I think about it I forgot to note before any of this really loud noticeable noise I would hear hear this noise slightly when making a big turn I.E going on a freeway ramp I started to notice the same noise
Does this indicate anything or help narrow anything down?
Also for the rest of my 24 mile trip to work I did not hear any noises even when coming to stops and parking.
Rule out those cats.
PG01
Up here to the right
Still betting on pickup tube in pan
I would very cautious driving it until you figure out the problem or just not drive it I would be leaning more towards that flexplate it could just happen to be catching on at the moment, you could go buy one of the those cheap inspection cameras and stick it up inside anywhere you can fit it in to check that flexplate
Big Mama
Virginia
Yeah I was hoping the cat had stuck combs but they would have come loose on that drive. I’m back on the flex plate wagon. As Wes stated you can get a cheap inspection camera and end the guesswork.
