In the middle os this valley pan, intake manifold gasket project. Thought I'd also change the coolant bypass seals (see pic) while I was in here. When I broke the coolant pipe loose, I was expecting to this shim with built in seal (like the pic shows). But I don't. The pipe connection is one piece. That one piece bolts directly to the head wihtout this shim and seal in between it. It doesn't, from the factory have these shims with built in O rings between it and the head. Am I basically adding these between the coolant pipe and head making the coolant pipe sit just a bit hight than OEM? Am I mising something??
