I have no idea what the specs are for our trucks for different sensors and vacuum.
Here's some readings of what I got but I don't know what the specs are
Intake manifold pressure (at idle) 4.35 PSI
Timing Advance (at idle) 22-24 degrees
Mass air flow rate 47.33 CFM
Turbo boost+vacuum Gauge -10.35
Vacuum -21.1 at idle and about -12.5 at 1500 rpms
volumetric efficiency 58%
fuel trim bank 1 longterm - 8.6%
bank 1 sensor 1 -1.56%
short term bank1 1.56%
bank2 long term 6.25%
bank2 sensor 1 -1.56%
bank2 short .78%
idles at about 625-640 rpms it fluctuates
idle under load is about 550 rpms
turns out my rpm gauge in the truck is reading high about 300 rpms more
I have no idea if these readings are in spec. Anyone know of a source where I can find this info?
Also on the torque app a ton of stuff doesn't work like IAC, EGR, Knock sensor etc... If you have the app can you tell me if it works for you? thanks
bank2 short .78%
