I got me a Tahoe!
j91z28d1
I did swap to a better, good injector. I deleted the CEL codes and started it a few times since. No CEL after injector swap but it still smoking.
is it running smoothly?
if it's smooth and fuel trims aren't crazy. you might drive around a bit. get it up to temp and see how It does.
if it's missing, it seems like it would be spark related. Definitely chack that power to coil
N
Nutro
No its idling rough. I just checked voltage at that coil (#4) and it shows 12v at key on, engine off and with it idling it fluctuates a little from 12.4 - 12.8 but I replaced the entire coil pack with all 4 coils to a different one I have and no change. Now I get P0122 and P0223 which is throttle body/TPS related?
N
Nutro
Still have quite a bit of clear fluid coming from muffler drain hole and white smoke that smells like combustion
N
Nutro
Well, I just noticed the radiator has a small leak in it somewhere so maybe that's why there's bubbles in the coolant overflow
Guncat
