I have a tech2, how do I tell the BCM to stop hyperflashing my LED turn signals?
So, are you showing me that this function is something that has to be added externally using the AutoSync?
The BCM has no facility for turning off bulb out detection natively?
Other BCM's of this same year do, so I am surprised if this is true.
Yep, they can do it. It cannot be done with GM bi-directional scan tools like the Tech-2 or MDI.
krbjmpr
Houston
Read somewhere here (TYF) that setting incomplete chassis in bcm turns off hyperflash.
Seems to work as a lot of GM van-based (3500, 4500) Class C Motorhomes have the stupid silly LED brake/tail light assembly in rear, incandescent on front, and whatever was handy on the sides.
What is even more interesting is that same chassis & year, same Cab options, etc... when doors are 'double' locked with remote one make/model will flash front signals, side marker, tail lights, clearance lights, etc. Oh, and honk horn too. But near identical floorplan on identical chassis will flash front signals, rear tail, but no other lights at all. I have not been able to find any similarities to identify disparity yet. I suspect one floorplan uses upfitter, other one doesn't.
petethepug
Michael
SoCal
The BT Dieselworks autosync does not turn off the hyperflash. It’s an option to have it programmed out in their custom BCM tune. It’s an add on to the Autosync module and of course has a bunch of other features in the package.
91RS
GA
No GM BCMs give this functionality to the end user. Some newer HD trucks can have the hyper flash disabled but the dealer has to call GM and request the special program and reprogram the BCM.
swt_wxw
