I need a schematic for BU/signal circuit for 2dr 96 tahoe
blizz
San Antonio, TX
i just bought a short circuit finder and need to follow the circuit to find the short. if anyone has this, please let me know. thank you.
foreverfalcon40
huh...what are your symptons...gonna take a stab at it and say your turn signal switch or resistors on your tail lights.
chris.
dont have any good info but ill throw out some ideas: Aftermarket Raido w/BU camera. Signal wire for the cam should be tapped into that, also ive heard but not too sure that there is a reverse wire signal in the rearview mirror, may only be with newer vechiles but ive seen it in some???Check possibly...Bulbs installed properly and correct rating/size/app???Again sounds stupid but who knows... If you still cant get it you could always run a new wire and bypass possilbe short and/or use signal from stalk and relay it to turn on the reverse lights, all this may sound good,bad right or wrong but another mind as work is always better than one. Plus ive noticed theres not a whole lot of traffic on here so ill throw my .02 in where i find suitable. Side note try to find someone that has an ALLDATA account im sure the schematic will be there...GL
blizz
blizz
San Antonio, TX
Hey thanks a lot Chris, I really appreciate it. I ended up fixing it and didn't really use that tool to do it, so I'm going to send it back. That's $45 I could spend somewhere else. So yeah I'm not even sure where the short was...it HAD to be at the front turn signal because I took the housing off and shook the wires a little and ta da...all started working fine. I know I didn't "fix" it and I'm sure the problem will return but for now as long as they work, it'll do until it warms up a little here. We're supposed to get into the teens here this week. Crazy for south Texas.
Thundergunexpress
